Changing an existing List Input source using Shortcuts/API
Joined: 5/18/2015(UTC) Posts: 150 Location: Australia
Thanks: 81 times Was thanked: 110 time(s) in 71 post(s)
Using the same method or shortcut to add an input, ‘AddInput’, is there a way to change an Input source using a shortcut or API code? The requirement is to change the Title file for a fixed Title’s Input via a Midi shortcut. The question was asked by another forum User last year, but only the manual procedure in the Settings dialogue was provided. http://forums.vmix.com/d....aspx?g=posts&t=5637
Groups: Guests
Do mean the ability to select a input without putting it in preview? I would love to have this for the app I am making ,for overlays ,instead of having 4 rows of every input I can have 1 with 4 dsk switches
Joined: 1/13/2010(UTC) Posts: 5,312  Location: Gold Coast, Australia Was thanked: 4708 time(s) in 1613 post(s)
Reloading title files during production is resource intensive and is not recommended. Can you describe a scenario where this would be needed?
You can already setup Title Presets for a single template, so you can setup all the speakers during a production and switch between them using the same template.
What about offloading the titles to a second machine and then bring that in via an NDI input. With that number, and the dynamic nature you describe, it would seem to me that it would be a dedicated operator's job to manage. I essentially do a similar thing with NewBlue Titler, and would suspect that those using CasperCG are the same.
