Joined: 12/1/2013(UTC) Posts: 56   Location: Ellenboro Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Currently running v16 & taking image from computer#2 with desktop capture. Is it possible to send the external output back to computer#2?
#2 is our presentation computer but I would like to use it occasionally for IMAG, showing the vMix streaming output.
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 203 time(s) in 169 post(s)
Yes.
It would probably be easier with vMix 17, but it is possible with vMix 16 & vMix 16 Desktop Capture on each PC.
Thank you. Can't use vMix17 b/c of an NDI problem. Both PC's are running win7.
Computer #1 is the main streaming PC and it sees & connects to computer #2 properly. Presentation PC #2 gets an error message when trying to connect back to #1. Running vMix 16 on both. Could there be an IP address issue?
Still unable to connect. Capture works great from one PC to main vMix PC but not in reverse. Both running v16. I will download v17 to see if that works any better.
Problem solved! One PC had incorrect firewall settings. working both ways with v16. Great software. Love it.
