Liberty Baptist Church
#1 Posted : Tuesday, July 12, 2016 4:26:35 PM(UTC)
Currently running v16 & taking image from computer#2 with desktop capture. Is it possible to send the external output back to computer#2?
#2 is our presentation computer but I would like to use it occasionally for IMAG, showing the vMix streaming output.
sinc747
#2 Posted : Tuesday, July 12, 2016 4:59:01 PM(UTC)
sinc747
Yes.
It would probably be easier with vMix 17, but it is possible with vMix 16 & vMix 16 Desktop Capture on each PC.
#3 Posted : Tuesday, July 12, 2016 5:36:18 PM(UTC)
Thank you. Can't use vMix17 b/c of an NDI problem. Both PC's are running win7.
#4 Posted : Tuesday, July 12, 2016 9:27:02 PM(UTC)
Computer #1 is the main streaming PC and it sees & connects to computer #2 properly. Presentation PC #2 gets an error message when trying to connect back to #1. Running vMix 16 on both. Could there be an IP address issue?
#5 Posted : Sunday, July 17, 2016 8:02:10 PM(UTC)
Still unable to connect. Capture works great from one PC to main vMix PC but not in reverse. Both running v16. I will download v17 to see if that works any better.
#6 Posted : Monday, July 18, 2016 8:53:29 PM(UTC)
Problem solved! One PC had incorrect firewall settings. working both ways with v16. Great software. Love it.
