Playlist or alternative help
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Hi
A bit stuck on achieving a playlist automation start and stop/return
no problem in getting it started (shortcut) but cann't seem to find a way to trigger it do do something at after the list item . Mind you the list is made up of images (set each at 5 second display).
There is probably some workaround to it just haven't figured it out yet
Ideally trigger it with a stinger and end the list with one
hints please
DUH
slideshow & on completion trigger :-)
