#1 Posted : Monday, June 27, 2016 3:10:43 AM(UTC)
Hi
A bit stuck on achieving a playlist automation start and stop/return
no problem in getting it started (shortcut) but cann't seem to find a way to trigger it do do something at after the list item . Mind you the list is made up of images (set each at 5 second display).
There is probably some workaround to it just haven't figured it out yet
Ideally trigger it with a stinger and end the list with one
hints please
#2 Posted : Friday, July 8, 2016 8:31:19 AM(UTC)
DUH
slideshow & on completion trigger :-)
