Feature Requests
Simulate a SD PTZ camera with a HD webcam
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
A bit the same request like the 4K Touch Zoom Switching request, but I want to use a Logitech C920 HD camera to simulate a SD PTZ camera, without using the Logitech software. I like to move the virtual SD image within the total frame with the arrow keys and zoom in and out with the + and - keys.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
What you describe is emulating the look of PTZ with flexible cropping, zooming & repositioning. You can already do this. You just need to preset the crop setup as separate shots. You can use the "Merge" transition to interpolate between shots.
What I would like to see is the ability to enter numeric values for the crop function. That would make it a lot easier to be exact in setting up shots.
Feature Requests
