wwdv
#1 Posted : Sunday, May 29, 2016 6:09:48 AM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
A bit the same request like the 4K Touch Zoom Switching request, but I want to use a Logitech C920 HD camera to simulate a SD PTZ camera,
without using the Logitech software.
I like to move the virtual SD image within the total frame with the arrow keys and zoom in and out with the + and - keys.
mjgraves
#2 Posted : Monday, May 30, 2016 2:53:25 PM(UTC)
mjgraves
What you describe is emulating the look of PTZ with flexible cropping, zooming & repositioning. You can already do this. You just need to preset the crop setup as separate shots. You can use the "Merge" transition to interpolate between shots.
What I would like to see is the ability to enter numeric values for the crop function. That would make it a lot easier to be exact in setting up shots.
