Cormac
#1 Posted : Monday, May 23, 2016 5:09:49 PM(UTC)
Cormac
Hi can I have a 4k camera running in on this750 graphics card or does it need to 've a 960 card as a minimum ?
Its an i7 computer with 64gig ram and an sad Windows drive but a 7200 rpm storage drive .
Would love to know before I buy the 4k version ?
Regards
Cormac
Mathijs
#2 Posted : Tuesday, May 24, 2016 4:24:51 AM(UTC)
Mathijs
Why don't you just try using the 60 days free trial?
Cormac
#3 Posted : Tuesday, May 24, 2016 2:14:00 PM(UTC)
Cormac
I think the demo
only allows up to HD def
Mathijs
#4 Posted : Tuesday, May 24, 2016 5:50:54 PM(UTC)
Mathijs
The 60 Day Trial of vMix has all the features of vMix Pro but without the ability to use resolutions greater than HD.
You are right, I'm sorry.
Only thing I can tell you, is that a 670 has no problem with it. That is the lowest geforce card I have here that supports 4k output. I would not put any money on the 750 though.
Maybe when you just add the input with some HD inputs it will work, but I would expect problems when you start building a nice show.
I go with the "70" versions of the geforce cards, and are quite satisfied. My main system is running with a GTX970 now and has no problem with 4k.
My backup system runs with the 670 and keeps up quite well as a backup. If it would be my main system I would upgrade the card.
thanks 1 user thanked Mathijs for this useful post.
Cormac on 5/24/2016(UTC)
Cormac
#5 Posted : Tuesday, May 24, 2016 6:23:03 PM(UTC)
Cormac
Hi that s great . Thank you for the info . Can I ingest the 4K just using my black magic mini recorder hdmi in or do I need to get a 4K capture card?
It he idea of being able to use a 4K camera to create many virtual inputs of zooms really appeals to me.
Cheers
Cormac
Mathijs
#6 Posted : Tuesday, May 24, 2016 8:34:37 PM(UTC)
Mathijs
You need a 4K input card. What you want is exactly what I'm playing with atm. I already tested it and the merge transition is awesome to do really nice pan/zooms from one shot to the other. It will need to be a good 4k camera that's very light sensitive though. You need a big depth of field.
