Hardware Compatibility
Is a 4k source on an nvidia 750 possible ?
Thanks: 9 times Was thanked: 3 time(s) in 3 post(s)
Hi can I have a 4k camera running in on this750 graphics card or does it need to 've a 960 card as a minimum ? Its an i7 computer with 64gig ram and an sad Windows drive but a 7200 rpm storage drive . Would love to know before I buy the 4k version ? Regards Cormac
Why don't you just try using the 60 days free trial?
I think the demo only allows up to HD def
Quote:The 60 Day Trial of vMix has all the features of vMix Pro but without the ability to use resolutions greater than HD. You are right, I'm sorry. Only thing I can tell you, is that a 670 has no problem with it. That is the lowest geforce card I have here that supports 4k output. I would not put any money on the 750 though. Maybe when you just add the input with some HD inputs it will work, but I would expect problems when you start building a nice show. I go with the "70" versions of the geforce cards, and are quite satisfied. My main system is running with a GTX970 now and has no problem with 4k. My backup system runs with the 670 and keeps up quite well as a backup. If it would be my main system I would upgrade the card.
 1 user thanked Mathijs for this useful post.
Hi that s great . Thank you for the info . Can I ingest the 4K just using my black magic mini recorder hdmi in or do I need to get a 4K capture card? It he idea of being able to use a 4K camera to create many virtual inputs of zooms really appeals to me. Cheers Cormac
You need a 4K input card. What you want is exactly what I'm playing with atm. I already tested it and the merge transition is awesome to do really nice pan/zooms from one shot to the other. It will need to be a good 4k camera that's very light sensitive though. You need a big depth of field.
