duck130883
#1 Posted : Saturday, May 14, 2016 1:44:02 PM(UTC)
duck130883
Is it possible to use the keyboard shortcuts to add the value to 1 Scoreboard ?
What I had specifically a Value field Add to that there is always a value of +1 ?
Thank you in advance for your reply.
#2 Posted : Saturday, May 14, 2016 2:25:56 PM(UTC)
@ duck130883
Value should be:
+=1
To raise by 1 with "Shortcuts"
sinc747
#3 Posted: : Saturday, May 14, 2016 4:50:01 PM(UTC)
sinc747
Here's a tutorial I did for a friend last year on setting up a scoreboard and using it with shortcuts.
Hope it's useful for you, too.
- Tom
duck130883
#4 Posted : Monday, May 16, 2016 4:20:41 AM(UTC)
duck130883
Thank you very much for the answer.
I have a couple of questions:
- Can anyone find a list of functions that I use as a value ?
- How can I write the value into the field settings for countdown ? (Start, duration ,stop time, reverse,... )
thanks in advance
Siroki
#5 Posted : Monday, May 16, 2016 4:39:20 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
duck130883 wrote:
thanks in advance
For timer you can also use shortcuts. I use it to to start/pause the timer
But i think duration you need to set up on title edit
Reverse you set up before on setting up your timer
