Hello, Is it possible to use the keyboard shortcuts to add the value to 1 Scoreboard ?
What I had specifically a Value field Add to that there is always a value of +1 ?
Thank you in advance for your reply.
@ duck130883
Value should be:
+=1
To raise by 1 with "Shortcuts"
Here's a tutorial I did for a friend last year on setting up a scoreboard and using it with shortcuts. Hope it's useful for you, too. - Tom
Hello, Thank you very much for the answer.
I have a couple of questions: - Can anyone find a list of functions that I use as a value ? - How can I write the value into the field settings for countdown ? (Start, duration ,stop time, reverse,... )
thanks in advance
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
duck130883 wrote:Hello, Thank you very much for the answer.
thanks in advance For timer you can also use shortcuts. I use it to to start/pause the timer But i think duration you need to set up on title edit Reverse you set up before on setting up your timer
