marosa
#1 Posted : Wednesday, May 11, 2016 10:21:50 PM(UTC)
marosa
Hi there,
Any update about Flash/*.swf Dynamic Text issue?
been searchin' bout this topic for awhile with no clue..
Mario
#2 Posted : Wednesday, May 11, 2016 10:56:13 PM(UTC)
@ marosa
Not exactly sure what you mean by "issue"...
Although vMix can "play" flash and swf files, there is really no built in means of controlling or taking advantage of dynamic fields within flash (unless you are able to build your own controller as Ambotz did a few years ago).
http://forums.vmix.com/d....aspx?g=posts&t=1139
Unfortunately, it seems unlikely that any additional support for Flash will be provided by vMix. However, with the new NDI technology, it opens up new possibilities to use vMix with Caspar CG (which does support extensive use of Flash).
marosa
#3 Posted : Wednesday, May 11, 2016 11:14:38 PM(UTC)
marosa
@Ice
the issue is minor but rather disturbing, it's when we use dynamic text to our flash animation (*.swf) file. somehow vMix will play that text as transparent no matter what color it has. while the text style is remain "unchanged"
even thou I can still use flash as my main title maker (as it can animate easily), but editing title's text from my flash program tooks more time than to do it from simple notepad editor... right?
Mario
stevespaw
#4 Posted : Thursday, May 12, 2016 8:21:02 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
If you use Flash with Dynamic text - You should be using CasparCG!!!
A perfect, very powerful solution. Free software with NDI outputs.
www.casparcg.com
There are installation instructions on this forum.
Steve
marosa
#5 Posted : Sunday, May 15, 2016 12:38:32 AM(UTC)
marosa
@Ice
@Steve
Caspar?? got it!!
gues I hv to start its tutorial asap :)
Mario
TVIason
#6 Posted : Sunday, May 15, 2016 5:32:05 AM(UTC)
TVIason
Was thanked: 9 time(s) in 8 post(s)
Marosa here is a tutorial I've made for working with CasparCG as a NDI source (in vMix)
tutorial . Tutorials for making graphics and how to use the program are also available on youtube.
