Hi there,
Any update about Flash/*.swf Dynamic Text issue? been searchin' bout this topic for awhile with no clue.. Mario
@ marosa Not exactly sure what you mean by "issue"... Although vMix can "play" flash and swf files, there is really no built in means of controlling or taking advantage of dynamic fields within flash (unless you are able to build your own controller as Ambotz did a few years ago). http://forums.vmix.com/d....aspx?g=posts&t=1139Unfortunately, it seems unlikely that any additional support for Flash will be provided by vMix. However, with the new NDI technology, it opens up new possibilities to use vMix with Caspar CG (which does support extensive use of Flash). Ice
@Ice
the issue is minor but rather disturbing, it's when we use dynamic text to our flash animation (*.swf) file. somehow vMix will play that text as transparent no matter what color it has. while the text style is remain "unchanged" even thou I can still use flash as my main title maker (as it can animate easily), but editing title's text from my flash program tooks more time than to do it from simple notepad editor... right?
Mario
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
If you use Flash with Dynamic text - You should be using CasparCG!!! A perfect, very powerful solution. Free software with NDI outputs. www.casparcg.comThere are installation instructions on this forum. Steve
@Ice @Steve
Caspar?? got it!! gues I hv to start its tutorial asap :) Mario
Joined: 11/7/2013(UTC) Posts: 66 Location: Netherlands
Thanks: 21 times Was thanked: 9 time(s) in 8 post(s)
Marosa here is a tutorial I've made for working with CasparCG as a NDI source (in vMix) tutorial . Tutorials for making graphics and how to use the program are also available on youtube.
