op music
#1 Posted : Wednesday, May 11, 2016 8:28:33 AM(UTC)
op music
Hello, for some days this problem happens to me, and Vmix closes, can anyone help? thank you
op music attached the following image(s):
errore vmix.jpg (228kb) downloaded 20 time(s).
ask
#2 Posted : Wednesday, May 11, 2016 8:30:13 AM(UTC)
ask
Sure. but you do need to describe the symptoms in detail, and what you have done, like checked the windows logs in Event viewer etc.
Also, can you translate the error message into English?
op music
#3 Posted : Wednesday, May 11, 2016 8:31:57 AM(UTC)
op music
I did nothing, while working out and I have to close this written Vmix
ask
#4 Posted : Wednesday, May 11, 2016 8:38:24 AM(UTC)
ask
Your CPU is fairly high, did you check Task Manager for all of the CPU usage? What other programs do you have running at the same time? You have at least 17 inputs does the same occur with less?
Try rebuilding your profile one input at a time to recreate the behaviour.
op music
#5 Posted : Wednesday, May 11, 2016 9:00:37 AM(UTC)
op music
I only have 3 inputs as photos
pc I7 ram 16gb
op music
#6 Posted : Wednesday, May 11, 2016 9:19:51 AM(UTC)
op music
error
Vmix stopped working.
windows: it is a problem that prevents proper operation of the program. If a solution is available, the program will close and automatically notified.
