Hello, for some days this problem happens to me, and Vmix closes, can anyone help? thank you op music attached the following image(s):  errore vmix.jpg (228kb) downloaded 20 time(s).You cannot view/download attachments. Try to login or register.
Joined: 10/13/2012(UTC) Posts: 1,157  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
Sure. but you do need to describe the symptoms in detail, and what you have done, like checked the windows logs in Event viewer etc.
Also, can you translate the error message into English?
I did nothing, while working out and I have to close this written Vmix
Your CPU is fairly high, did you check Task Manager for all of the CPU usage? What other programs do you have running at the same time? You have at least 17 inputs does the same occur with less?
Try rebuilding your profile one input at a time to recreate the behaviour.
I only have 3 inputs as photos pc I7 ram 16gb
error Vmix stopped working. windows: it is a problem that prevents proper operation of the program. If a solution is available, the program will close and automatically notified.
