Kaf
#1 Posted : Monday, May 2, 2016 7:09:55 PM(UTC)
Kaf
I would like to make a simple command who replace an Input by another one.
Let's Add an Input
http://127.0.0.1:8088/API/?Function=AddInput&Value=Flash|RTMP://mytream.tv
Now in vMix I add an overlay on it etc...
I would like to replace this Stream by another without remove the Input, I just want to "replace" or "change" the URL or file of my Input.
How can I do that ?
Thank you for your time :)
smudge1977
#2 Posted : Saturday, January 13, 2018 5:41:35 PM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
I need the same thing so i can automate the update of content but make sure any shortcuts or multiviews that reference the original still work correctly.
BenoIt
#3 Posted : Friday, January 26, 2018 4:33:49 AM(UTC)
BenoIt
Good feature!!! any update?
