Hi, I would like to make a simple command who replace an Input by another one. Let's Add an Input http://127.0.0.1:8088/API/?Function=AddInput&Value=Flash|RTMP://mytream.tv Now in vMix I add an overlay on it etc... I would like to replace this Stream by another without remove the Input, I just want to "replace" or "change" the URL or file of my Input. How can I do that ? Thank you for your time :)
You have been a member since:: 4/3/2014(UTC) Views messages in topic : 58 Location: UK
Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
I need the same thing so i can automate the update of content but make sure any shortcuts or multiviews that reference the original still work correctly.
smudge1977 wrote:I need the same thing so i can automate the update of content but make sure any shortcuts or multiviews that reference the original still work correctly.
Good feature!!! any update?
