Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
An integrated RTMP server like in Livestream Studio 4.0 would be very helpful to get an easier ingest of RTMP encoder signals instead of using Wowza streaming engine to change it first to RTSP.
Joined: 5/2/2016(UTC) Posts: 1 Location: California, USA
vMix already supports RTMP ingest under Flash/RTMP input in the Input Selection window. The format for the RTMP URL is: rtmp://web_site_url/live/myStreamWith myStream being the stream key See http://www.vmix.com/help17/Flash.html for more details about RTMP ingestion Sean
seancallahan wrote:vMix already supports RTMP ingest under Flash/RTMP input in the Input Selection window. The format for the RTMP URL is: rtmp://web_site_url/live/myStreamWith myStream being the stream key See http://www.vmix.com/help17/Flash.html for more details about RTMP ingestion Sean Thank you very much for your answer. What does web_site_url mean? I use the Teradek Vidiu. You need to give the device a RTMP Server address as stream target. How does Vmix provide me this address? Thanks again Jürgen
 1 user thanked trilive for this useful post.
Thanks: 74 times Was thanked: 4 time(s) in 3 post(s)
I also can not stream rtmp signal from Cube , and JVC GY-HM200E. In Livestream 4 it works like a charm. rtmp://xxx.xx.xxx.xxx/live/myStream where xx is my no-ip public address, port 1395 is open. In LS4 it works, in Vmix 17 - media playback error appears
