sertody
#1 Posted : Wednesday, April 20, 2016 4:29:07 AM(UTC)
sertody
Hello
after update of windows 10 the vMix not work.
I have delete and reinstalled vMix ... i see label ... "" unable to register the DLL/OCX RegSvr32 filed with exit code 0x5 ""
can you help me ?
Thank you
sertody
Mathijs
#2 Posted : Thursday, April 21, 2016 12:46:36 PM(UTC)
Mathijs
Open a command prompt as administrator and try this command: sfc /scannow
This will scan your protected systemfiles for missing or corrupted files and will try to fix any abnormalities.
code 0x5 is Access Denied, So it cannot load the file, or has no access to it, or is missing it.
RegSvr is used to add or update registry keys, so it might also mean it cannot write the registry update, because of the user not having rights to do so.
So also try to run as admin by right clicking and choosing the run as administrator option.
Also check if your virus scanner isn't keeping vmix from updating the registry.
You can also try to find out which key it wants to update within the registry and find that within regedit and look at the permissions on that key.
For this you should read the windows logs within the event manager.
thanks 1 user thanked Mathijs for this useful post.
sertody on 4/22/2016(UTC)
Similar Topics
Warning to those who use the startup script workaround (General Discussion)
by TBacker 7/30/2025 6:51:08 AM(UTC)
ERROR D3DStartup Overflow or underflow in the arithmetic operation. (General Discussion)
by nelsongarcez 2/11/2024 2:25:38 AM(UTC)
NDI run on startup options (NDI)
by SPSTech 1/20/2023 12:49:23 AM(UTC)
vMix long startup time and companion error (General Discussion)
by priortothat 5/23/2022 9:47:59 PM(UTC)
Startup Profile (Feature Requests)
by cmcloughlin 4/20/2021 6:02:08 AM(UTC)
Adding cameras - blank screen on startup but multiple resets get it to work (General Discussion)
by mhallet 3/20/2019 10:14:42 AM(UTC)
build a basic startup computer (General Discussion)
by rttiii 1/13/2018 12:40:01 PM(UTC)
emSize Startup ERROR (General Discussion)
by pweisz 9/6/2017 2:43:41 PM(UTC)
VMIX using all RAM at program startup - HELP (Hardware Compatibility)
by jammerxd 11/4/2016 8:13:42 PM(UTC)
vMix startup error e_invalidarg HELP (General Discussion)
by Kridas 9/30/2016 5:51:15 PM(UTC)
Error Startup - (Video.txt) (General Discussion)
by horebtv 1/29/2016 10:27:29 PM(UTC)
GoPro Startup causing high CPU usage (General Discussion)
by Len56 2/25/2015 2:01:54 PM(UTC)
Padlock on at startup option (Feature Requests)
by wwdv 9/30/2014 3:27:22 PM(UTC)
Startup options (Feature Requests)
by rrpro 5/17/2014 8:41:32 AM(UTC)
by wwdv 11/9/2013 1:46:30 PM(UTC)
