Hello after update of windows 10 the vMix not work. I have delete and reinstalled vMix ... i see label ... "" unable to register the DLL/OCX RegSvr32 filed with exit code 0x5 "" can you help me ? Thank you sertody
Rank:: Advanced Member
Open a command prompt as administrator and try this command: sfc /scannow
This will scan your protected systemfiles for missing or corrupted files and will try to fix any abnormalities.
code 0x5 is Access Denied, So it cannot load the file, or has no access to it, or is missing it. RegSvr is used to add or update registry keys, so it might also mean it cannot write the registry update, because of the user not having rights to do so. So also try to run as admin by right clicking and choosing the run as administrator option.
Also check if your virus scanner isn't keeping vmix from updating the registry. You can also try to find out which key it wants to update within the registry and find that within regedit and look at the permissions on that key. For this you should read the windows logs within the event manager.
 1 user thanked Mathijs for this useful post.
