Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 756
I was playing with the new NDI feature and installed vmix on a second machine.
I got everything working successfully for a while then restarted the vmix on the first machine.
On the first machine all I get now is a registration error, I have reinstalled, deleted the program data folder, tried everything I can think of but the instance on the first machine will not now start.
When looking at the support site, I see, yes, you can have two instances on seperate machines but only running one at a time, I don't know if that caused it.
Anyone know how I can fix this on the first, its that machine that's the important one. The other was just to make an NDI thing. I think I can use casparcg for that now anyway.
TIA Daz
