philh
#1 Posted : Friday, March 18, 2016 2:28:38 PM(UTC)
philh
New user looking for some help if possible!
I am new to VMIX and have created a custom title / overlay (just a simple png. image background and single line of text over the top).
I set up a vmix preset file which when i open this on my laptop opens fine, custom title opens no problem. But when i go to open the vmix preset on my desktop the custom title is there but no image.. All my files are synced using syncplicity.
Any ideas?
Bandit62
#2 Posted : Friday, March 18, 2016 3:15:06 PM(UTC)
Rank: Guest
Groups: Guests
If it is a PNG file, use the "Overlay" button to have it as a title....There are four numbers under each input.....click on one under the PNG file you created....it should work, and it should overlay on the output video....
Hope I have helped you, but check the Help files for anything you need to know....
Use this link for the Help Files, and download ...
philh
#3 Posted : Friday, March 18, 2016 3:45:34 PM(UTC)
philh
Unfortunately the png. isn't there when i open the present on my desktop computer.. I'm hoping someone can help me find why it isn't there.
ask
#4 Posted : Friday, March 18, 2016 4:54:31 PM(UTC)
ask
Reload the .png file into to image input so that your 2nd computer knows the path to the file.
