Help with Titles / Overlays
New user looking for some help if possible!
I am new to VMIX and have created a custom title / overlay (just a simple png. image background and single line of text over the top).
I set up a vmix preset file which when i open this on my laptop opens fine, custom title opens no problem. But when i go to open the vmix preset on my desktop the custom title is there but no image.. All my files are synced using syncplicity.
Any ideas?
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
If it is a PNG file, use the "Overlay" button to have it as a title....There are four numbers under each input.....click on one under the PNG file you created....it should work, and it should overlay on the output video....
Hope I have helped you, but check the Help files for anything you need to know....
Use this link for the Help Files, and download ...
Bandit62 wrote:If it is a PNG file, use the "Overlay" button to have it as a title....There are four numbers under each input.....click on one under the PNG file you created....it should work, and it should overlay on the output video....
Use this link for the Help Files, and download ... Unfortunately the png. isn't there when i open the present on my desktop computer.. I'm hoping someone can help me find why it isn't there.
Reload the .png file into to image input so that your 2nd computer knows the path to the file.
