Mike_in_tX
#1 Posted : Tuesday, March 15, 2016 12:57:57 PM(UTC)
Mike_in_tX
I saw in the February vmix show, the guys used a Behringer UMC404 audio interface, connected to the system via USB. My question is this, in VMIX, does each of the 4 audio inputs from the UMC404 appear as a separate audio interface in vMIX? Or does it only show one master input from the UMC0404 that combines all the inputs?
Thanks!!
sinc747
#2 Posted : Tuesday, March 15, 2016 1:35:50 PM(UTC)
sinc747
You have been a member since:: 8/2/2013(UTC)
Was thanked: 204 time(s) in 170 post(s)
You can add an audio input as a Window Device or an ASIO device. Using the "UMC ASIO Driver" you get all four inputs.
- Tom
sinc747 attached the following image(s):
UMC404HD screen cap.PNG (28kb) downloaded 11 time(s).
Mike_in_tX on 3/15/2016(UTC)
florent45
#3 Posted : Sunday, June 11, 2017 9:51:28 AM(UTC)
florent45
Is the same for output ? Can you use the four output (Master, Headphone, A, B) with the UMC ASIO Driver ?
