Behringer UMC404 - 4 tracks or onei n VMIX?
I saw in the February vmix show, the guys used a Behringer UMC404 audio interface, connected to the system via USB. My question is this, in VMIX, does each of the 4 audio inputs from the UMC404 appear as a separate audio interface in vMIX? Or does it only show one master input from the UMC0404 that combines all the inputs?
Thanks!!
You can add an audio input as a Window Device or an ASIO device. Using the "UMC ASIO Driver" you get all four inputs.
- Tom
sinc747 attached the following image(s):  UMC404HD screen cap.PNG (28kb) downloaded 11 time(s).You cannot view/download attachments. Try to login or register.
 1 user thanked sinc747 for this useful post.
Is the same for output ? Can you use the four output (Master, Headphone, A, B) with the UMC ASIO Driver ?
