cambysys
#1 Posted : Tuesday, March 1, 2016 7:45:37 AM(UTC)
cambysys
I am trying to get VMIX to multicast stream over the LAN. The WMV method is not acceptable because it is http.
There seem to be several streaming servers around and I starting off trying to use EVOStream.
I'm happy to change if someone has a better solution that works.
I need to set up a stream output on vmix that EVOStream can injest.
In their documentation they have a sample stream available on the net and one gets it using this:-
rtmp://s2pchzxmtymn2k.cloudfront.net/cfx/st/mp4:sintel.mp4
I was hoping that I could create a rtmp stream with vmix.
I entered some info into the Stream" setup but it bombs out with an error about FFMPEG
See below
Help appreciated
FMPEG.Exited
ffmpeg started on 2016-02-29 at 21:43:57
Report written to "C:\ProgramData\vMix\streaming\streaming 20160229-214357.log"
ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc
libavutil 55. 2.100 / 55. 2.100
libavcodec 57. 3.100 / 57. 3.100
libavformat 57. 2.100 / 57. 2.100
libavdevice 57. 0.100 / 57. 0.100
libavfilter 6. 9.100 / 6. 9.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video:audio=vMix Audio':
Duration: N/A, start: 207350.458000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (UYVY / 0x59565955), uyvy422, 1280x720, 29.97 tbr, 10000k tbn, 29.97 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 04059100] TCP Buffer has been set to 3990528 bytes
rtmp://127.0.0.1/test: Input/output error
cambysys attached the following image(s):
ScreenHunter_143 Feb. 29 21.42.jpg (99kb) downloaded 2 time(s).
ScreenHunter_142 Feb. 29 21.36.jpg (73kb) downloaded 2 time(s).
djevo1
#2 Posted : Friday, March 4, 2016 3:09:46 PM(UTC)
djevo1
It looks like you forgot the /live in the url. We use wowza and that can trip some people up.
