Rank:: Advanced Member
You have been a member since:: 10/16/2014(UTC) Posts: 32 Location: San Jose, CA
Hi all,
I just wanted to see what your thoughts are on using a Raid configuration for recording on vMix. I'm trying to decide what route I should go for a recent dedicated vMix workstation purchase. I'd like to have the ability to record 4 ISOs and a PGM using ffmpeg's mpeg2 option at the highest video and audio bit rate. Im torn between a 4 drive (7200rpm, 128mb cache, SAS, 6gb/s, 4tb enterprise) Raid 10 configuration and/or just 2-1tb Samsung 850 SSDs.
Thanks in advance for any suggestions.
Joined: 2/6/2015(UTC) Posts: 103  Thanks: 20 times Was thanked: 7 time(s) in 6 post(s)
If you can get the performance you need out of the SSDs, less moving parts and parts to fail is always a better thing. Not to mention power requirements, heat, space.
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
I'm using 2-1TB 850s in RAID 0 configuration, primarily for replay. Everything works perfectly so far. Blackmagic Speed Test shows just under 1GB/Sec.
Thanks for the input so far guys! Is raid 0 necessary for SSDs on instant replay?
