Feature Requests
ASIO audio channels in Multicorder
Thanks: 2 times Was thanked: 7 time(s) in 5 post(s)
Being able to choose multiple ASIO audio channels as sources in multicorder would be great. This is to have separate audio if something needs to be fixed in post afterwards for example (and later replace the VOD-version after a livestream).
Of course this is only applicable if you use a multichannel audio-interface that feeds the separate channels into vMix.
Joined: 10/16/2014(UTC) Posts: 32 Location: San Jose, CA
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
You can use Reaper for rec and mix audio. And you can use ReaRoute ASIO to send audio from Reaper to vMix. :-)
Feature Requests
