pop
#1 Posted : Wednesday, January 13, 2016 7:36:27 PM(UTC)
pop
Was thanked: 7 time(s) in 5 post(s)
Being able to choose multiple ASIO audio channels as sources in multicorder would be great. This is to have separate audio if something needs to be fixed in post afterwards for example (and later replace the VOD-version after a livestream).
Of course this is only applicable if you use a multichannel audio-interface that feeds the separate channels into vMix.
emylio
#2 Posted : Thursday, March 31, 2016 11:09:28 AM(UTC)
emylio
+1 !
epicenter800
#3 Posted : Thursday, March 31, 2016 1:54:03 PM(UTC)
epicenter800
+1, please.
Cpilcher
#4 Posted : Thursday, March 31, 2016 2:20:37 PM(UTC)
Cpilcher
This would be great.
emylio
#5 Posted : Saturday, April 30, 2016 11:42:10 AM(UTC)
emylio
You can use Reaper for rec and mix audio.
And you can use ReaRoute ASIO to send audio from Reaper to vMix. :-)
