tgdzapa1
#1 Posted : Monday, December 21, 2015 9:32:34 AM(UTC)
tgdzapa1
Hi
I try and try but it's doesen't works :-( .
With every replay I want to show off the score graphic on overlay 1. I tried with the trigger function
without success.
Thanks for help.
BR
Patrick
tgdzapa1 attached the following image(s):
#2 Posted : Wednesday, December 23, 2015 8:57:43 AM(UTC)
@ tgdzapa1
I'm not sure about the "Instant Replay" integration of "Triggers" and/or if it interferes with "Stinger" overlays , but otherwise, it seems to work fine for me.
What 'parameters' have you tried?
I would be inclined to use:
OnTransitionIn/OverlayInput1/(*your chosen Input for Overlay*)/(*your desired transition Duration*)/(*your desired Delay*)/ADD
