Instant Replay
Replays without score graphic (on overlay 1)
Joined: 1/21/2014(UTC) Posts: 83 Location: sportwebtv.be
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
Hi I try and try but it's doesen't works :-( . With every replay I want to show off the score graphic on overlay 1. I tried with the trigger function without success. Thanks for help. BR Patrick tgdzapa1 attached the following image(s):  vmix.PNG (16kb) downloaded 9 time(s).You cannot view/download attachments. Try to login or register.
@ tgdzapa1
I'm not sure about the "Instant Replay" integration of "Triggers" and/or if it interferes with "Stinger" overlays , but otherwise, it seems to work fine for me. What 'parameters' have you tried? I would be inclined to use: OnTransitionIn/OverlayInput1/(*your chosen Input for Overlay*)/(*your desired transition Duration*)/(*your desired Delay*)/ADD
Instant Replay
