Tonysal123
#1 Posted : Sunday, November 15, 2015 4:00:18 PM(UTC)
Tonysal123
What would be the preferred method to control multiple vMixs,? For example, via some external command ( either by hardware panel or software ) switch the input sources to multiple vMix units. Would like to have both a primary & backup vMix unit that are controlled from one central device.
Thanks,
T
thanks 1 user thanked Tonysal123 for this useful post.
daniel514 on 12/5/2015(UTC)
jhebbel
#2 Posted : Sunday, November 15, 2015 8:28:38 PM(UTC)
jhebbel
You you use a MIDI controller that has traditional MIDI out instead of just USB, that signal can be split.
thanks 1 user thanked jhebbel for this useful post.
Tonysal123 on 11/15/2015(UTC)
