Joined: 9/5/2015(UTC) Posts: 10 Location: Los Angeles
What would be the preferred method to control multiple vMixs,? For example, via some external command ( either by hardware panel or software ) switch the input sources to multiple vMix units. Would like to have both a primary & backup vMix unit that are controlled from one central device.
Thanks, T
 1 user thanked Tonysal123 for this useful post.
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
You you use a MIDI controller that has traditional MIDI out instead of just USB, that signal can be split.
 1 user thanked jhebbel for this useful post.
