rrpro
#1 Posted : Friday, October 23, 2015 6:13:11 AM(UTC)
rrpro
Hi! I'm using a capture device but the image has visible lines with movement.
On the properties I see that the Deinterlacing is disabled. How can I activate it? (on vmix settings, all is by default).
richardgatarski
#2 Posted : Friday, October 23, 2015 6:52:58 AM(UTC)
richardgatarski
Make sure that when you add the Camera select an interlaced Frame rate.
rrpro on 10/23/2015(UTC)
rrpro
#3 Posted : Friday, October 23, 2015 7:03:30 AM(UTC)
rrpro
Thank you! Solved!
