Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi! I'm using a capture device but the image has visible lines with movement. On the properties I see that the Deinterlacing is disabled. How can I activate it? (on vmix settings, all is by default).
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
Make sure that when you add the Camera select an interlaced Frame rate.
 1 user thanked richardgatarski for this useful post.
richardgatarski wrote:Make sure that when you add the Camera select an interlaced Frame rate. Thank you! Solved!
