Photos transitions doesn't work on overlays
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi Martin!
I'm writing because i want to put some ads in vMix using a folder with the PNG files. When i import the folder there is no problem. When i setup a transition, everything seems to be ok, but the problem appears when i put that input as an overlay. When i do that, transition seted doesn't work. The input works with the seted time between each PNG file, but transition doesn't work (just cut between each file). I don't know if this is a normal work of overlays (i don't think so), or just a bug.
Thanks! Regards!!
Joined: 1/13/2010(UTC) Posts: 5,316  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
This is currently by design. In the final release of vMix 8 you will be able to use photo transitions through the overlays.
Martin vMix
