guztavo
#1 Posted : Monday, October 15, 2012 1:03:11 PM(UTC)
guztavo
Hi Martin!
I'm writing because i want to put some ads in vMix using a folder with the PNG files.
When i import the folder there is no problem. When i setup a transition, everything seems to be ok, but the problem appears when i put that input as an overlay. When i do that, transition seted doesn't work. The input works with the seted time between each PNG file, but transition doesn't work (just cut between each file).
I don't know if this is a normal work of overlays (i don't think so), or just a bug.
Thanks! Regards!!
#2 Posted : Tuesday, October 16, 2012 12:08:41 AM(UTC)
This is currently by design. In the final release of vMix 8 you will be able to use photo transitions through the overlays.
guztavo
#3 Posted : Wednesday, October 17, 2012 1:08:06 PM(UTC)
guztavo
Thanks Martin!
Regards
