rrpro
#1 Posted : Tuesday, August 25, 2015 2:32:42 PM(UTC)
rrpro
Hi! I was trying the midi controller to control faders but I'm having trouble.
The buttons work OK but the Faders and Knobs are not detected.
I was using the key "MIDIControllerChange" and SetFader, SetVolume...
I did some debugging and Found that the Faders are "Pitch Bend" events.
Is that function available for shortcut or could be included?
rrpro attached the following image(s):
ovinas
#2 Posted : Tuesday, August 25, 2015 3:16:51 PM(UTC)
ovinas
What about using the Korg Kontrol Editor to change the control mode?
ClementN
#3 Posted : Tuesday, August 25, 2015 3:20:38 PM(UTC)
ClementN
Romania
Hello rrpro,
I was just testing nanoKONTROL2 today and everything was ok assigning both the faders and knobs using the "Find" button in "Shortcuts" tab .
"Control mode" in Korg Kontrol Editor: CC
thanks 1 user thanked ClementN for this useful post.
rrpro on 8/25/2015(UTC)
rrpro
#4 Posted : Tuesday, August 25, 2015 6:25:35 PM(UTC)
rrpro
ClementN wrote:
Hello rrpro,
Very cool, thank you very much. Perfect.
rrpro
#5 Posted : Tuesday, August 25, 2015 6:56:25 PM(UTC)
rrpro
Would it be possible to "Fast Forward" or "Fast Backward" X seconds with a Key on the Shortcut?
ON.tv Channels
#6 Posted : Thursday, October 15, 2015 4:03:27 AM(UTC)
ON.tv Channels
Hi
Did anyone using this super little Korg nanoKONTROL2 build a working template for vMix?
If so, would it be possible to have it available for download?
TIA, John
calamityjane
#7 Posted : Friday, October 16, 2015 9:33:11 AM(UTC)
calamityjane
ClementN wrote:
Hello rrpro,
Just jumping into this conversation, as usual I have nothing of value to add but looking for help.
vMix seems only to recognize (at least appears that way when you employ the "FIND" button in shortcuts) the Channel and Note but not the velocity of a fader.
My second issue is when using the FIND appraoch for assigning functions to the MIDI controller there is no "Value" entry box.
Scenario:
I want to use my Korg nanoKontrol2 to control a scorebug in Titles. Two issues;
1. No VALUE box to enter a digit when using the Korg
2. I was hoping to use the velocity segement of the fader to adjust the TIME in the scorebug.
Any thoughts
Whit
doyousee.me
#8 Posted : Monday, October 19, 2015 9:13:37 AM(UTC)
doyousee.me
this would be nice, be able to either use a button (or jog) to do search or a slider.
the former would be a better suit for my workflows though
M@ik
