Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi! I was trying the midi controller to control faders but I'm having trouble. The buttons work OK but the Faders and Knobs are not detected. I was using the key "MIDIControllerChange" and SetFader, SetVolume... I did some debugging and Found that the Faders are "Pitch Bend" events. Is that function available for shortcut or could be included? rrpro attached the following image(s):  Untitled3.png (31kb) downloaded 21 time(s).You cannot view/download attachments. Try to login or register.
What about using the Korg Kontrol Editor to change the control mode?
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
Hello rrpro,
I was just testing nanoKONTROL2 today and everything was ok assigning both the faders and knobs using the "Find" button in "Shortcuts" tab .
"Control mode" in Korg Kontrol Editor: CC
 1 user thanked ClementN for this useful post.
ClementN wrote:Hello rrpro,
"Control mode" in Korg Kontrol Editor: CC Very cool, thank you very much. Perfect.
Would it be possible to "Fast Forward" or "Fast Backward" X seconds with a Key on the Shortcut?
Thanks: 107 times Was thanked: 2 time(s) in 2 post(s)
Hi
Did anyone using this super little Korg nanoKONTROL2 build a working template for vMix?
If so, would it be possible to have it available for download?
TIA, John
Joined: 9/26/2014(UTC) Posts: 110  Location: Canada Thanks: 39 times Was thanked: 5 time(s) in 5 post(s)
"Control mode" in Korg Kontrol Editor: CC Just jumping into this conversation, as usual I have nothing of value to add but looking for help. vMix seems only to recognize (at least appears that way when you employ the "FIND" button in shortcuts) the Channel and Note but not the velocity of a fader. My second issue is when using the FIND appraoch for assigning functions to the MIDI controller there is no "Value" entry box. Scenario:I want to use my Korg nanoKontrol2 to control a scorebug in Titles. Two issues; 1. No VALUE box to enter a digit when using the Korg 2. I was hoping to use the velocity segement of the fader to adjust the TIME in the scorebug. Any thoughts Thanks Whit
Joined: 8/4/2012(UTC) Posts: 129 Location: the Netherlands
this would be nice, be able to either use a button (or jog) to do search or a slider.
the former would be a better suit for my workflows though
M@ik
