Hi all.
Is there a way for vMix to cicle (switch)through the cameras?
ie: Camera 1 is selected, 5 minutes latter switches to camera 2, 5 minutes latter switches to camera 4, and so on, all done automaticaly (like a video switcher used in security cameras.
Dear Martin, if that could be implemented would be super.
Thanks and thumbs up for a fantastic piece of software.
Nucas
Joined: 3/30/2014(UTC) Posts: 224 ![Man Man](/Themes/yafpro/male.gif) ![United Kingdom United Kingdom](/Content/images/flags/GB.png) Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
It can be done using play list, add your cameras click on play list and add your cameras as seen in the pic below, double click on each camera in the play list and change the timings and make sure you have loop turned on. close play list then click on it so it turns red then it will start. Len56 attached the following image(s): ![](/Themes/yafpro/icon_file.gif) PL1.jpg (138kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
![thanks](/Themes/yafpro/heart_small.png) 1 user thanked Len56 for this useful post.
Thank you very much Len56.
nucas
