nucas
#1 Posted : Friday, August 21, 2015 9:37:24 AM(UTC)
nucas
Hi all.
Is there a way for vMix to cicle (switch)through the cameras?
ie: Camera 1 is selected, 5 minutes latter switches to camera 2, 5 minutes latter switches to camera 4, and so on, all done automaticaly (like a video switcher used in security cameras.
Dear Martin, if that could be implemented would be super.
Thanks and thumbs up for a fantastic piece of software.
Nucas
Len56
#2 Posted : Friday, August 21, 2015 10:16:38 AM(UTC)
Len56
It can be done using play list, add your cameras click on play list and add your cameras as seen in the pic below, double click on each camera in the play list and change the timings and make sure you have loop turned on. close play list then click on it so it turns red then it will start.
Len56 attached the following image(s):
thanks 1 user thanked Len56 for this useful post.
nucas on 8/21/2015(UTC)
nucas
#3 Posted : Friday, August 21, 2015 10:24:44 AM(UTC)
nucas
Thank you very much Len56.
nucas
Len56
#4 Posted: : Friday, August 21, 2015 11:45:06 AM(UTC)
Len56
Your welcome.
