Black Magic Design Intensity Pro
Forum Rank:: Newbie
You have been a member since:: 8/24/2012(UTC) Posts: 3 Location: Germany
thank you for VMIX. Again, a question about BMD Intensity Series: It is only possible to use the adaptor as an input- OR outputdevice? Even it can generally be used in both ways at the same time? Is this an issue that will be fixed sometime or is it a "feature" ;-)
It's a limitation of the Intensity card itself. These cards have a chip that can only do one thing at a time hence why both is not possible.
Martin vMix
Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
Actually BMD Intensity does loopthrough by default (though you have to make sure you are using the correct output option in BMD control panel), this might do the trick in some cases.
Dundurs
 1 user thanked dundurs for this useful post.
Forum Rank:: Newbie
Thank you both for the information guys!
