stschaudt
#1 Posted : Wednesday, August 29, 2012 10:25:57 AM(UTC)
stschaudt
thank you for VMIX. Again, a question about BMD Intensity Series:
It is only possible to use the adaptor as an input- OR outputdevice? Even it can generally be used in both ways at the same time?
Is this an issue that will be fixed sometime or is it a "feature" ;-)
#2 Posted : Wednesday, August 29, 2012 12:05:20 PM(UTC)
It's a limitation of the Intensity card itself.
These cards have a chip that can only do one thing at a time hence why both is not possible.
stschaudt on 8/29/2012(UTC)
dundurs
#3 Posted : Wednesday, August 29, 2012 12:28:45 PM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
Actually BMD Intensity does loopthrough by default (though you have to make sure you are using the correct output option in BMD control panel), this might do the trick in some cases.
Dundurs
thanks 1 user thanked dundurs for this useful post.
stschaudt
#4 Posted : Wednesday, August 29, 2012 10:11:23 PM(UTC)
stschaudt
Thank you both for the information guys!
