Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
Hello, Im want to use the following configuration in vMix: 1. all production in 1080@50i 2. 4 camcorders via 4 intensity pro 3. 4 video delays 4. fullscreen 5. external out via 1 additional intensity pro At this point I have MSI GT620 PCIE 1GB GDDR3 DVI+HDMI+VGA LP graphic adapter which produces render time of 50ms for this setup. The integrated Intel HD 4000 has even worse results. The question is what should I look for in a graphic adapter to be able to accomodate my vMix configuration? There are many variables such as cuda cores, mhz, memory, memory type, which are of the most importance? Currently I have the following options available for one slot cards (preffered to save space for another intensity pro) but I guess the list could be extended if there are some good suggestions. 1. HP AMD Radeon HD 6570 1GB PCIe x16 DH 2xDP 1xDVI-I QP027AA link2. Dell ATI FirePro V4800 490-12504 link3. HP NVIDIA Quadro 600 1GB PCIe x16 Card WS093AA linkWhich card would be best suited for my config? Also I could consider 2-slot cards if absolutely necessary. Some options: 1. Leadtek GeForce GTX 550 Ti, 1GB GDDR5 (192 Bit) GTX 550 TI 1024MB REV:B link2. Powercolor Radeon HD 6850, 1GB DDR5 (256 Bit), HDMI, DualDVI AX6850 1GBD5-DH linkThanks, Dundurs
Can it satisfy my needs of full HD 4cam+delay production? What render time should I expect from this card?
I'm using a PNY GeForce GTX 560ti with three 720p HD cams, no delay, no sync issues.
Famous Pictures wrote:I'm using a PNY GeForce GTX 560ti with three 720p HD cams, no delay, no sync issues. Famous Pictures, thanks for suggestion. Is it this one url ? Core count is the same, mhz is a bit less, memory is 2x less but more powerful compared to Zotac. I guess Zotac should also do the trick. By the way what is your average rendering time?
Review and comments about price/performance ratio of GT640 from here are are all going one way :) Martin, if I were to consider HD7750 (supposedly much better for the same price compared to Zotec, for example this one I think is a single slot card) or HD6670 (still better for lower price according to some comments and also the tech spec), is there any argument for nVIDIA instead of ATI? Dundurs
