How to use overlay in Playlist ?
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
I like to use PlayList as an "automation" tool for starting or ending a show (or other parts).
For example, we start the show with an intro (which is a transparent .mov over a camera). Then put a lower third after some seconds (an overlay, too).
Do you think will be possible to achieve that with Playlist ?
Joined: 2/29/2012(UTC) Posts: 10 Location: New Jersey, USA
Hi ClementN
Yes you can. Example:
1. Add a color input 2. Use "Multi View" and "Position" from the input settings to set up your layers (in this case the transparent movie over the live input) 3. Repeat the above steps, creating a second input, and add the lower thirds 3. Add them to your playlist and awe your audience!
Topbunk
Excellent! Thank you very much!
