ClementN
#1 Posted : Thursday, May 24, 2012 4:18:27 PM(UTC)
ClementN
Romania
I like to use PlayList as an "automation" tool for starting or ending a show (or other parts).
For example, we start the show with an intro (which is a transparent .mov over a camera). Then put a lower third after some seconds (an overlay, too).
Do you think will be possible to achieve that with Playlist ?
topbunk
#2 Posted : Thursday, May 24, 2012 7:13:02 PM(UTC)
topbunk
Rank:: Member
Hi ClementN
Yes you can. Example:
1. Add a color input
2. Use "Multi View" and "Position" from the input settings to set up your layers (in this case the transparent movie over the live input)
3. Repeat the above steps, creating a second input, and add the lower thirds
3. Add them to your playlist and awe your audience!
Topbunk
ClementN
#3 Posted : Friday, May 25, 2012 3:00:17 AM(UTC)
ClementN
Romania
Excellent! Thank you very much!
