watchfulone
#1 Posted : Thursday, May 14, 2015 3:00:55 PM(UTC)
watchfulone
Was thanked: 17 time(s) in 14 post(s)
Good day Martin, good job as always and all the best as you and your team go forwarding with vMix
Can you please add in vMix support for Davinci Resolve, adding the required formats and codecs? The NLEs is really nice to work with and feature pack, but current vMix MP4, AVI, WMV, Mpeg is not recognizable to Davinci Resolve.
Davinci is very specific as to which formats and codecs it supports.
For Windows, this is the list:
DPX
Cineon
Tiff
OpenEXR
CinemaDNG
Alexa Arri
Canon EOS C300
Phantom cine
RED r3d
Mpeg 4 Video mov
H.264
Uncomp RGB QT mov RGB 8 Bit
mov BGRA 8 Bit
mov ARGB 8 Bit
mov RGB 10 Bit
Uncomp YUV QT mov UYVY 8 Bit
mov UYVY 10 Bit
Uncomp YUV MXF mxf UYVY 8 Bit
Uncomp YUV MXF mxf UYVY 10 Bit
Uncomp RGB MXF mxf 1080i & 1080p 10 Bit
Apple ProRes 4444 mov
Apple ProRes 422 mov Apple ProRes 422 (HQ)
mov Apple ProRes 422 (LT )
mov Apple ProRes 422 (Proxy)
DNxHD mxf
http://www.indietalk.com/showthread.php?t=44707
thanks 1 user thanked watchfulone for this useful post.
PFBM on 5/19/2015(UTC)
PFBM
#2 Posted : Tuesday, May 19, 2015 6:51:46 PM(UTC)
PFBM
Hi !
use Cineform HD codec for now in AVI container.
http://shop.gopro.com/so...studio/GoPro-Studio.html
it´s free.
Resolve plays it on windows.
Let´s wait until Martin gets MXF recording into Vmix to get full crossplatform compatibility windows/osx
Cheers,
PFBM
mark
#3 Posted : Wednesday, November 25, 2020 11:36:49 PM(UTC)
mark
I too would like just 1 video format that Vmix outputs that will work with Da Vinci.
Nothing I have tried seems to work.
Any ideas on how to achieve this out there?
dmwkr
#4 Posted : Saturday, December 12, 2020 7:16:40 PM(UTC)
dmwkr
Have you tried recording in vMix AVI and converting it to ProRes with the vMix Media Converter?
#5 Posted : Saturday, December 12, 2020 8:12:59 PM(UTC)
vMix already lets you add your own codecs and options for recording.
Any codec supported by FFMPEG can work.
Just add your own presets to the ffmpegformats.xml file.
It's also possible to use any software or hardware recorder in combination with vMix, either using the External outputs or the NDI protocol or the HDMI out.
aircooled76@gmail.com
#6 Posted : Sunday, March 6, 2022 12:50:51 PM(UTC)
We do corporate video production, quite often 3-4hour records re-encoding all the recordings would take lots of logistics and time that we would prefer not to spend.
Would be amazing to be able to edit vMix AVI directly in Resolve (really wanting to get away from always crashing premiere pro)
Thanks as always for the amazing work with vMix
#7 Posted : Tuesday, March 26, 2024 11:19:49 AM(UTC)
@PFBM
Do you know if you loose power on the PC or some other show killing moment happens will the Cineform codec be corupt? vMix AVI's main feature for me is it does not corrupt if interrupted (or is recoverable)
Originally Posted by: PFBM Go to Quoted Post
Hi !
it´s free.
Cheers,
PFBM
