Input name instead of input number in API
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
I am using this API command: ?Function=PreviewInput&Input=20
When I move an input the number is not corresponding anymore with the wanted input. Is it possible to call the name of the input instead of the input number?
Already found a solution: http://127.0.0.1:8088/API/ shows a list with input GUID codes which can be used instead of the input numbers. Thanks to
