wwdv
#1 Posted : Sunday, May 3, 2015 8:38:11 AM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
I am using this API command: ?Function=PreviewInput&Input=20
When I move an input the number is not corresponding anymore with the wanted input.
Is it possible to call the name of the input instead of the input number?
wwdv
#2 Posted : Sunday, May 3, 2015 9:31:32 AM(UTC)
wwdv
Already found a solution:
http://127.0.0.1:8088/API/ shows a list with input GUID codes which can be used instead of the input numbers.
Thanks to
