Hi, I have a card Aja Xena Lhe win 8 works with WMIX? thanks
I apologize the card is installed on the PC, but in Vmix not see, thanks
Hi, I just installed on a PC with windows 7 but Vmix does not recognize it, can anyone help? maybe there volgiono other driver? I installed the drivers from AJA. thanks
Joined: 7/9/2014(UTC) Posts: 9 Location: Grass Valley, CA
The current Kona Lhe Plus model would, however the the XENA/KONA LHe is no longer supported by our current driver package (12.x) that vMIx has implemented support for.
Kona Lhi, Kona 3G, Kona Lhe+, Kona 4, IoExpress, IoXT and Io4k do all support the driver versions that work great in vMIx.
thanks for answering, so I can not install the new version of Vmix? thanks
vmix should work just fine, :) the Xena card just wont work in vMix because it is one of our older cards that doe not run on drivers that vMix supports.
